antonlevay
i think i had a bad gingerbread part 1 file and got stuck in bootloop and now battery is dead and wont charge. any help please or do i need to go ahead and order a new battery? does new batteries come charged?
No more so than an extended battery or a case. You don't need them, but when they pull your butt out of the fire you are sure glad that you had them. If you plan on sticking with Motorola phones, then this is a good investment.
Well in my case an extended battery is more useful than that cable, and if you have an extended battery that means you also have a spare battery that you can charge with a battery wall charger that you can get on ebay for like $5-$6, a lot better than $35. Also, since I don't plan on sticking with Moto, it makes even less sense to me to get that cable![]()
Point taken, you also plan ahead. There are a lot of people that do not plan ahead. I plan on sticking with Moto, especially if the Google merger thing works out.
Cool, your point is valid too, and you are most likely right about people not planning ahead, but people should think ahead before doing things to their phones that can possibly brick them.
But, I think VS's advice should be followed here, make sure your battery has enough juice to do the job, though I suggest starting at 100%; once you are more experienced you can live a little more dangerously![]()
i guide you in the right path. ^_^As an eLearning Design/Developer I always train to the lowest common denominator. Most people have good intentions, but it is hard for people to plan for all of the possible outcomes, especially when they are not comfortable with the process. I took a lot of lumps when I first started flashing ROMs to my first Droid. Thankfully there are a lot of good people (wink, wink) on this forums (and others) that take the time to help.
yes sir! learned my lesson good. i think ill leave the new radio alone and just stick with liberty for now after i get it going again
which also have ubuntu, so i dont have to wait forever with the yellow dots everytime. ok im done
thanks Saint for all the info and i look forward to learning much more! im so glad my lg ally days are long gone
its no problem bud, we are here to help.
just remember we are better technical support answerers than 611 from your verizon handset![]()
it did tell me that i need to put a motorola battery in and mine was invalid
i guess i should have just waited because the guy came just a few minutes ago to lend me his battery lol. thats what i get for being impatient! i just hope that it is the battery and not anything else. i will be ordering a new battery tomoroow and see if that fixes it
bad day turns to worse i guess
