any luck
So after I relocked, I tried to
RUU_Vigor_VERIZON_WWE_1.00.605.3_Radio_RS_0.93.00.0914r_3161C1_9K_NV_8k_1.12_9k_1.83_V_APT_release_216261_signed and keep getting your battery is below 30% everytime I try it. I just took the batteries out of the external charger.
When I try permanently install your recovery, I get to the fastboot flash recovery <recoveryname>.img; the phone restarts to blank white HTC page. And yes I redownloaded everything again.
I was able to unlock again.
I'd be happy to get my phone back to stock, so that I could just use it again.
ive found most folks who are having prollems despite everything looking correct,are having something running on the PC thats interfereing. some have only been able to overcome the issue by using a "virgin" pc or laptop thats never had any phone stuff installed on it.
make sure youve disabled htc sync,pdanet,easy tether,and any other program capable of comunicating with the phone.
also try different cables and ports. if all else fails,put mini-adb_vigor on a flash drive and take it to a friends house and try a different PC
on the batteries,are you sure your external charger is working properly?
you also will not be able to install that ruu,unless youre still on that old firmware
youll need to use the ruu for the
current build- 2.01.605.11
