I've seen HTCDumlock around on the XDA forums, what does it actually mean?
I know I'm using the right command (fastboot boot test.img) and everytime I try to get to recovery otherwise or flash a new recovery it hangs and I have to pull the battery.
what is "test.img? that you are trying to boot?
if you want the latest firmware,youll save yourself alot of grief by simply updating the firmware in hboot,then flashing the stock rom in recovery. there is nothing special about the OTA.
awsome! glad you are sortedIt took about an hour, but my SIM card and wifi finally "kicked in" and everything is working great now. I remember the same thing happened the first time I rooted it as well, not sure why. But it's working! Thanks again for all your help, it is greatly appreciated. . .you should have a "Donate Now" button.
Edit: Also a quick note: My pics and vids were all deleted (as expected), but everything else on my phone (contacts, apps, most settings, texts, emails) remained untouched. A pleasant surprise.
I clicked recovery on the power+volume down menu and now I get a screen with a red triangle and exclamation mark! What now? I went through HTC Dev just fine and then got confused, clicked that and then this happened. D: Edit: Okay. Now everything is back to normal and I can access my phone and the power+volume down menu, but I'm still confused on what to do after HTC Dev...
if the update has just knocked out your root access,and everything else is functioning correctly,you wont have to start from scratch. simply follow steps 2 and 3 of the OP guide again(assuming youre still unlocked):Hey guys, i was rooted on gb but today ics forced it's way in..my question is do i have to start from scratch to get my root back or is there something different i have to do..super user is allinstalled.been so long since I've done this i forget thanks
Ok nevermind on my question. I was having issues flashing the ruu but if i would've paid attention I would have followed the direction of flashing the SetMainVersionLOW.zip then running the ruu. After I did that everything worked like a charm! As always Scotty thank you fr everything. Your guides and instructions are outstanding!
I got through all the steps fine up until booting after flashing the recovery. I selected hboot and then recovery but then it just gets stuck on the splash screen. I have an HTC One X+ and I'm running Windows 8. Please help
well,you have followed a guide for the rezound,and as such have used a recovery image not compatible with your phone. try step 2 again using twrp(http://forum.xda-developers.com/showthread.php?t=1995002) or clockwork(http://forum.xda-developers.com/showthread.php?t=2074396)![]()
