diestarbucks
I have been experiencing a light screen flickering on some of the lighter colors, most notably lighter grays. I saw where Novox77 had mentioned having a similar issue in another thread but didn't see if he had any sort of resolution for the problem. After some searching I saw that the One X was plagued with this issue and that HTC had released an OTA that seemed to have fixed the issue for them. Info on that can be found here:
Screen Flicker - Response from HTC - Page 89 - xda-developers
Is anyone else experiencing this problem, or heard of any sort of solution? I hesitate to just swap it out because otherwise the device is perfect. If it is just software related I can hold off since it isn't horribly noticeable.
. Like you said though if there is an issue like the One X, a software update will fix it. I would only ever return a phone over hardware . Software is easily fixed..
