Help Screen hanging up
rchez16
Member
Just recently when I turn my phone on in the morning (I shut down each night; with fastboot enabled) the screen is all laggy and gets hung up. It's hard to describe; for example, if switching between screens the screen will show a sort of trailing effect; another example is the words used to describe my apps blur. I am forced to do a full restart to correct the problem. Otherwise, the phone is working fine.
I have used GoLauncher and GoLocker for a while without any problems. The only new app that I have installed is the Scalado Album.
Any one else with similar issues? Suggestions?
I'd remove any recent apps or *recently updated apps* from the phone and see if the problem goes away. Alternatively you can use a system monitoring app and see what is hogging up your processing power.
I installed OS monitor last night to check on things. I did not see any one app that was hogging the processor. It did show that my "/data" folder was almost 90% full, so I cleared out some of the "data" from many apps, including G Music, and a few other large apps. I did notice things were snappier.
I am going to try system panel lite to see if there is a difference between it and OS monitor.
Thanks for the help.
