Hello Galaxy Lovers!
I solved the problem that screen goes black even if your phone is away from your chin and I'm sure it will also help you to get rid of unlock during calls.
In my case, one of my apps called
System Pannel was killing important service. It is called
com.samsung.phoneinfo
This was causing the problems. Of course, I tested more than 50 times by killing this service and make phone calls. In this situation, my solution was put this service on exclude mode and it works.
I know there's thousands apps for managing active apps and services .(Task killers, Advanced task killers...etc).
Please make sure your utility apps doesn't kill
com.samsung.phoneinfo.
Here's how you do.
1. You have to battery pull. Turn off your phone, Take your battery out, Put it back and turn your phone on.
2. Go to your apps that kills
inactive apps and find
com.samsung.phoneinfo. make it this in your exclude lists.
3. Turn off your phone and turn it on
4. Test it. (I called 611 because i don't get charged
**** I know it works because, my 4 Friends who has Fascinate tried and got their Fascinate working and they are happy.
Please if this solution helps you, reply on this thread so that we can help other people*******
Good Luck guys.
P.S.
Personally, I do not recommend using ATK. Sometimes, it will kill so much apps that phone needs it. You can managed this with
system panel apps that I'm using. It is better, because you can manually kills your app when you feel like your phone is slowing down. Also, Smart phone is different than iphone. you have to manage this phone continuously.
I use
System Pannel lite to kill apps like Active apps, Background Apps and Inactive Apps with one touch key. Of course, few apps or service, you have to move it to your exclude list so it won't get killed.
I also use apps called
Memory booster once a day and
quick app clean cache once a day. Then finish with
HistoryEraser once a day.
If you would like to feel little bit faster, download
Spar Parts and Change your Window animations and Transition Animations Normal to FAST. It will help too.
Thank you for reading and I look forward to hearing from you guys.
Thanks!!!
