I just got my Bionic and noticed that while charging it the screen freezes and I cant use the phone at all.. it wont accept calls and i cant do anything... is there a setting that i should be changing? if so, where and how?
As dooglad asked, Are you using the included charger and cable?Also make sure the phone is turned on when you plug it up to charge. If your plugging it into your computer to charge swipe down on the top bar and choose USB connection and make sure it's set to Charge Only.
