Hello, does anybody use or know of good screen protectors that can cope with our curvy screens? Tried the eBay ones and found they just lift up around the corners.
Cheers
That aside, you still get the slightly concave shape of the screen (which is a Gorilla glass for extra scratch resistance) and the not-quite-a-unibody design at the back.
thanks firedesire
soulz - i'm sure it's a great screen, but i'd feel better having a protector on it![]()
thanks firedesire
I still believe they are the best, had a Zagg on my desire for 18 months and it's still in use, that makes it quite cost effective. Put one on my SXE before I'd even given it its first charge. The finish has a slight mottled effect if you look at it under certain lights but as a rule the looks is as if there is no screen protector on it and it fits a treat, just watch out when fitting as there is a top/bottom of protector.... handy hint, protector has the word 'zagg' in tiny lettering - this goes at bottom right of phone screen. All the best. PS I have no connection to Zagg other than my screen purchase !
I've got one of these on my XE..... brilliant poduct..... make sure you follow the instructions to the letter and its a sinch to apply![]()
does it have a matte finish, which doesn't show up fingerprints, or is it the glossy finish which does?
