Originally Posted by Tim K
I probably wouldn't mess with trying to fix it myself. $160 from the mfg seems reasonable as long as they turn it around quickly. Check with ifixit, but I don't think it sounds like a good idea.
Here's the thread with the samsung contact info:
Unbelievably crappy luck = cracked glass
From other threads here, sounds like it takes about a week to 10 days for Samsung to repair and return.
Reading the teardown over at iFixit leads me to recommend that U Don't Fixit.
Specifically the warning on step 15:
"The glass is fused to both the display and the display frame. So don't crack the glass unless you're good with a heat gun, or you're fond of replacing the glass, display, and frame together ($$$)."
