Hi everyone, this is my first post. I've read around on the forums before but never signed up until now. So if I break some rules or something, I apologize.
I recently purchased an unlocked Telus HTC Hero. It's running off my Rogers SIM card with no issue. I was reading and I noticed that apparently you cannot put apps on an SD card without rooting. No problem I thought, I can do it. So I was following some guide that was linked to from here. I got to the point of downgrading. The guide told me to downgrade using "RUU_Hero_HTC_1.76.405.1_RE..." I attempted this however I received a "error 140 bootloader version error". After googling it, I came across some other guide that said if the previously mentioned RUU failed, run 2.73.405.5 downgrader instead. I attempted this, and it worked. However I noticed that now I believe the phone thinks it's European as the languages to choose from are only European. After downgrading to what I believe was 2.73.405.5 I had a change in heart in rooting (As I felt I couldn't manage it at this point), and wished to revert back to what my phone was (Minus the apps and personal data n stuff) prior to my attempt. I did firmware upgrades in hopes that it would bring me back to what I was. It appeared to, with some minor changes:
-To revert to factory settings, is now found in "privacy" instead of "security".
-The languages are for European countries.
Is there any way to get my phone back to what it was? And from where I am now, how hard would it be to root?
***Update*** I decided to redowngrade and attempt to root. Took me some time, but did pull it off. Now my only issue is that the languages are all European languages. Is there a way to change it to NA rather than EU? Thanks in advance.
You access it by powering on while holding the HOME button, although many custom ROMs also have an option to boot to recovery under the "Reboot" option in the Power menu.
