Root [SCRIPT] Velocity Master Script Beta
savoxis
Android Expert
The Master Script​
Code:
(1) Apps2SD Tools
(2) Show or Block Ads
(3) Change Clock and Notifcation Bar Colors
(4) CPU Information and OC
(5) Change Boot Animations
(6) Toggle Turbo and JIT
(7) Remount System
(8) Backup
(9) Restore
(0) Exit
I have created a menu driven Ease-of-Use tool for using my scripts to... well... make it easier! This tool is ONLY for Velocity 4, and it is still in BETA, the only reason I am semi-publicly releasing this is to expedite bugsmashing and feature implementation. I kanged Tridents update-script so it wont even let you flash it onto anything BUT Velocity 4.
Installation: Download zip, place on sdcard, reboot into recovery, flash, reboot. There is no wiping required.
Use: Just open up a terminal, type su to root, and invoke using master -r
Please keep in mind this is only a beta there are still a few quirks.
.4b changes/known issues:
  • Rewrote JIT/Turbo section to check to see if it is already enabled to avoid bootloops.
.3b Known Issues:
  • Should have resolved both previous issues, removed green boot animation and reworked pause function
  • JIT Toggling seems to be causing boot loops. Please keep away from the JIT menu until I get this resolved.
.2b Known Issues:
  • script information, and a2sd information scripts will run very fast and drop you back in the menu. I have a fix for this and will update soon.
  • Green boot animation doesn't display correctly.
Grab it and help with feedback please. New ideas welcome
DOWNLOAD .4b​
DOWNLOAD .3b​
DOWNLOAD .2b​
Can we post issues in this OP please? I am noticing based on other posts that JIT enable sends phone into a boot loop? I was unaware of this, I would like to get a definitive answer.
This is probably due to dalvik-cache needing to be wiped afterwards. If someone has a few minutes could they try enabling, then if stuck in boot loop, reboot to recovery and wipe dalvik?
My development phone is currently on loan to a friend so there are some things I cant test for a few days, if I can get an answer as to whether or not it is the Dalvik causing the issue, I can patch it today.
The JIT does when you enable it it reboots phone then it takes you to the verizon logo i was able to flash a backup however
Now are you giving it enough time? It will take a long time. Also since hit isalreay enabled that may cause issues ill put in a conditional to see if its already on
Well mine took me forever to restore lol i had to take out the battery 1000 times and it only went in to recovery when i press send menu and pwr it dident do it for vol down send and power
So should I take the silence as a good omen that all my latest changes are bug free?
Any ideas for improvements?
I haven't either... I just wish I knew how to use the color change. I was thinking of flashing the velocity.3 oc kernel, think that would cause an issue with the stock rom?
im getting as far as the master
-r --run run script
-h --help this message
any advice on the code i have to run next to enter the number coding on the script?
Velocity 0.4 has an updated version of that kernel, why flash an old one?
I didn't see one seperate with his latest rom I was just throwing that out since he had it as an option and not standard like in .4. I'm using the stock rom for now because I didn't fair so well with .4.
For those of you wanting to use this on other roms:
Be patient, after this is included in the next VELOCITY release (absolutely no idea when so don't ask) I WILL make a generic version of this script for use with any rom. There are alot of things that need to be adjusted for this to work without causing boot loops on other roms, BUT I will release a generic copy TO DEVS so they can include it in other roms
Other ideas I have for the script:
The ability to choose between kernels and have the script reboot into recovery and flash.
Fonts. Not too sure how many I should include but Ill start with a few in the next beta.
Themes, flashable themes will work the same as kernels.
I am going to get my dev phone this weekend; just got over being sick. I plan on finishing this project over the weekend along with some other things.
I plan on implementing the following:
  • Font changing
  • Movement of /data/velocity to /system to save much needed space in data
    [*]Another idea i am toying with is having allot of additional boot animations and fonts and whatnot up on awesomazing or savoxis to allow for downloading them ondemand to save space.
    [*]Also the option to have a directory on /sdcard/velocity/user so you can put fonts or boot animations in the folder yourself to install
What do YOU think?
Feedback allows for better programs and more advanced feature sets.
I gots idea. Maybe you could make an app so that when you use script for themes and fonts, we can get it off the app. Is that possible? Jw
