If I take a picture or download something with my SGS2, it saves it on the device itself. Is there a way to change that so it saves on the SD card by default?
If you open the Camera app and access its Settings, you can choose the Storage Location (Phone or Memory card). i don't know of a similar setting to alter the default location for downloaded files, though.
I'm not sure if all browsers are the same. But if you use dolphin hd go to settings, data storage then download directory. You can now write in the name of a folder on your external sd and it will save there.
