adam_hilluk
I have been having alot of issues with the Hero and therefore am unsur whether this is an SD card issue or handset. Anyway...
Basically when i put my SD card in the phone can access all of the files for a while. However after a bit the Audio player ceases to work and a message comes up saying, "Sorry, audio player does not support this type of file" (or words to that effect). Additionally the phones ASTRO reader stops working, and picsay wont save to SD card.
I dont know also whether it could be because i am using Advanced Task Killer and maybe killing something i shouldnt?
Another thing to consider is that i recently upgraded from 2gb memory card (no issues) to this 8gb. When i did this i copied absolutely everything off 2gb including files i didnt know purpose of HTC related. Has this caused issue?
Any help would be most appreciated as this is a really frustrating issue and i dont know what to do!
Adam
Adam
