LaXBuLLeTPrOoF
im trying to restore my backup from cwm but everytime im try to restore back up it gives me an error and it wont do the back up, can anyone help me
im trying to restore my backup from cwm but everytime im try to restore back up it gives me an error and it wont do the back up, can anyone help me![]()
no its the same way as its always been, havent changed anything to it.
is there a way to fix it or have i lost the back up forever? and do i really need it, im always using the custome roms u guys always create, thaks by the way.
You also can restore your back up by going to back up and restore then go to advance restore then choose from internal SD card then select restore boot after that your gonna do the same to system /data /cache /SD ext after you restore all those just reboot your your phone.
it worked, thanks so much for the help, do you know why it wouldnt back up from cwm, again thaks sooooooo much![]()
