Root SD card partitioning using amon RA partition option?
Paul8944
Hi
After a bit of advice please.
I have been reading lots recently regarding partitions on SD cards.
I used amon RA recovery to partition my SD card. How does this compare with using gparted and does this create an ext 3 or something similar
Thanks in advance
we always recommend gparted. Its fine making a partition, if it works. But if it doesnt you need gparted to fix it anyway. No idea what ext it makes
