Root SD card problems after installing Virtuous ROM
Agreed. It's not Virtuous ROM's fault. It's either card failure or user error.
Running Virtuous 3.2 and 3.1 before that and have had zero issues, even after adding mods over top of it.
Nice work, Rafi.
I just want to report that I'm having the same problem after running the root upgrade on my Droid Incredible. I can't access the software on my SD Card. I can't install from Market for software that is on the SD Card. Titanium can't restore. I can access the files using file explorer. Should I try offloading the drive/formatting fat32/and putting everything back? If not, I will try the procedure to go back to straight 2.2 when I come back from some errands later today. While it is very possible that there is an issue with my sdcard, I have not had one up until now. Any other possibilities? This is just after I rooted then moves a bunch of software to my sdcard. Is it possible the sdcard move does not perform properly? I wish I had done more testing after rooting but before moving software to my sdcard. Oh well...Any other helpful troubleshooting tips would be appreciated. And I do appreciate all of the hard work that goes on here with rooting/roms. Thanks so much!!!
So the restore worked and everything is fine. Before I moved everything I could to my 32gb external drive. It trashed firefox, dolphin hd, and a couple of other programs that I run. Does some software require that it stay on the internal drive even though I can move the software to the external drive by running a program?
