G
g60madman
Guest
OK,
So I bought a new 8GB HC SD Card for my Wife and it worked fine. I was in the middle of doing a backup with titanium for her so I can flash the new CM7. During the backup the phone hard locked. I pulled the battery and rebooted and now the SD card won't show up in CM7 or CWM. If I put the same SD Card in my Triumph it reads just fine. I did wipe cache / dalvik and reset permissions in CWM but still no dice, and tried multiple known good SD cards. I was going to do a factory wipe, but if I do her phone will be useless with out the SD card. I won't even be able to install gapps or her apps and that will mean an unhappy Wifey which means pain for me, and lots of it!
Anything else I can try?
But, since it is new there shouldn't be much on it.
