Help SD card via bluetooth?
D
Deleted User
Guest
Hello !
Did a google but nothing really useful.. =\
Are we able to access the SD card via bluetooth? Cuz sometimes I don't have by cable around..
I've connected Desire with the laptop (windows7) via bluetooth, I was able to send files to phone etc.. But I can't see it as a different drive so I can browse the SD card (as with USB) =\
Is it possible?
Thx in advance! :rolleyes:
no you cant afaik
you can do it using an app like websharing
or you can use es file explorer lan tab to browse shares on the pc
