I'm going to post this here since its SD card related.
Just switched out my default 2 gig SD for a 32 gig SD
I'm noticed that the original 2 gig sd has folders in it that are missing from the 32 gig.
I have not yet activated the phone... does the software create the files and folders as needed
For instance thew original 2 gig had folders such as DCIM , RECORDINGS ,ZEMAIL
I was playing with the camera and recorder
Am I correct in assuming that when U put a new SD in phone it probably formats it to a default state then as U use certain features it adds folders and files that it needs
I also noticed in a folder that both cards now have called Android within it is a folder called DATA and in that the original had a folder called com.google.android.apps.maps
which the new 32 gig sd does not have
