czseven
Ok i have alien kernel installed in phone throne that keeps telling you updates ready.?. TWRP root ,no Rom... i backed up phone then wiped or factory reset phone put sd card back in , all was good so far. so i wiped card then i then another recovery/ backup to card, YES CHECKED MADE SURE I HAD ROOT BEFORE BACKUP. Phone was back to factory at this point except for kernel and TWRP root, i used play store app and downloaded dropbox and e3 or es3 file app tried instaling Rom the 3rd Rom on list ,in zte warp m860 all things root guide. Tried installing the zip every wich way onto sd,
WENT TO TWRP RECOVERY CLEARED CACHE + DALVIK, went and created one more backup while i was in recovery , immediately went to zip in recovery it will not flash gets stuck making its recovery during flash it says
/sd-ext not found and stops , EVERY F~& TIME....
I did look this up didn'tfind an exact fix most use cwm not twrp.
PLEASE HELP ME I KNOW IT CAN B FIXED PRETTY EASY LOL ;~|}~
GRRRRR!!!!!!!!
GRRRRR!!!!!!!!
