yes your card will be reformatted when you upgarde to ext 4 so make sure that you back up accordingly.
I don't know about that, as I have myself gone into recovery, and upgraded from ext 3 to ext 4 twice with not so much as a hiccup?yes your card will be reformatted when you upgarde to ext 4 so make sure that you back up accordingly.
Edit: but better safe than sorry to make a nand!!
Hey Mikey! Yeah, I did do a nand bu then I went ahead and copied my sdcard to laptop BUT as it turns out, I don't think I need to copy anything back! After the upgarde to EXT4, I toggled the USB-MS and all the sdcard was still there! I rebooted and did a terminal emulator a2sd check and it 'sees' the EXT4. So, I guess I'm good to go...
EDIT: so, I'm a bit confused with what ocnbrz posted about the sdcard being formatted??? Seems that IF that were the case, I wouldn't be seeing the 'Removable Disk' and all its contents?
See thisHey Mikey! Yeah, I did do a nand bu then I went ahead and copied my sdcard to laptop BUT as it turns out, I don't think I need to copy anything back! After the upgarde to EXT4, I toggled the USB-MS and all the sdcard was still there! I rebooted and did a terminal emulator a2sd check and it 'sees' the EXT4. So, I guess I'm good to go...
