Help SD not available from PC
double
im running stock no modifications. have always had access to sd after mounting to pc. now the 8gb phone drive is available but the sd is not. when i go to my computer and click on drive "h" it says application not available.
Try another sd card... Or try the sd card in another phone, you need to isolate the problem before troubleshooting.
Make sure you are in disk drive mode and USB debugging is checked also. Never know maybe a setting got changed accidentally. Perhaps remove the card and clean the contacts just for grins. Can't hurt.
