DaRayvn
[GUIDE][07/07/11]How to Partition your SD Card - xda-developers
are these the instructions to follow for partioning?? just wanted to make sure there isnt another set of them somewhere else.....
there's a few things im wondering about, like....
number 3, says enter 1024 or 2048?? whats the difference?? then it says and the rest for FAT??? is it saying pick one of those for ext2, for example 1024, then enter 2048 for FAT???
i also see nothing about doing the cache, dalvik cache, and data wiping along with using superwipe....just says go to the wipe menu and wipe everything in it.....hmmm....
any input on how any of you on the forums do it would be appreciated....i just wanna make sure i do it right....thanks
