Has anybody tried to partition their SD card yet in prep for 2.2/Apps2SD? If so, it's be nice to get a procedure documented here since many of us will have the need for this in the hopefully near future.
Ok, I did some research. Can anyone verify whether the following sounds on the level:
Use Clockwork partitioning feature, make the ext 512 Mb, swap 0. Only necessary on CM6 or any other ROM that have Apps2SD built in. Won't work on stock 2.2 when released.
