MolBasser
All,
Several websites have sort of confused me, and I didn't find it on search. So, please accept some noob questions.
1. I only have the stock 2GB SD memory card (lame I know, but I haven't filled it yet which is usually my signal to buy a bigger card. Yes, I know they are cheap). Some sites say that you need a card bigger than 2GB. True? And why is this (nandroid backup space?) Simply attaining SU shouldn't take this much memory right?
2. Some sites say that you have to remove PdaNET from your computer before you attempt root, others, no mention.
3. Some sites say you have to remove drivers before installing the pack that is downloaded for the unrevoked method, others say you can use the "update drivers" option (I'm winXPpro sp3)
Anyway, figure I'll root before the update and wait for native Dinc Gingerbread ROM mods to come out, and save root rather than lose root and get what verizon/htc give me.
Thanks for reading and TIA for responses.
MolBasser
MolBasser
