windsorclarenc
I'm trying to get a2sd to work properly. I just used Amon Ra to partition my SD card again. I partitioned about 1gb to each the swap and the apps. I flashed the new MIUI ICS I saw here. When I try to install a2sd in terminal emulator it tells me "SD card not mounted properly". I unmounted then remounted the SD card and it still gives me the same error. Is there anything I can do to fix this?
What I'm using
ROM: MIUI ICS with a2sd built in (the newest)
Kernel: Tiamat that came with said ROM.
SD card: 32gb class 10
Recovery: Amon Ra (2.3.6?)
What I'm using
