mariadroid
does anyone know why or how my 32g SD is now reading 4
does anyone know why or how my 32g SD is now reading 4![]()
i checked and i am trying to move some things to ex sd and says full no more memory...showing 4You sure that's not the internal sd card? the internal is 4.
Reboot? Are you seeing this in settings?
we're all here to help.not sure in the status bar was the icon..and it says damaged SD card..when i click on it it ask me if i want to reformat itIt will erase it. Why is it damage? :3
didnt even think of that will try....Try re-inserting the sd card. Maybe that it'll fix it
PS1. Please back up immediately to your pc and get another card....my sdcard just went.this is the second time i have had a problem with the sd card hopefully the last time![]()
I have the biggest one that the phone holds I will try the app to move things over thanks![]()
