Hello guys, total noob here.
I tried to create a partition using MiniTool on my SDCard. First I saved all info from the SD card to my computer, then MiniTool asked me to format my SDCard, so I did, tried creating a second partition to work with Link2SD but failed in creating the partition. I decided to copy all my info back to the SDCard, it shows that it copies the data but when I check on my phone the SDCard shows as being empty ... Can't copy anything into it.
Can the card be salvaged and will I be able to copy my apps back to it, if so, how?
Thanks in advanced guys.
Also what would be the best way to create a second partition?
Was able to figure it out guys. Thanks
