Sennheiser VMX 100 BT won't pair
thrider
When in pairing mode, the droid recognizes the device as VMX 100. I touch the entry and it shows "pairing", but it never pairs and doesn't show the password screen. The device text under VMX 100 returns to "Pair with this device"
Anyone else have this issue?
Welcome to the AF forums and enjoy your visits !! :cool:
You need to post your question in the Droid Forum ... to get a best chance of an answer
Yes I got my Droid today and I have exactly the sames issues pairing as you.
CUrious. Where does pairing happen? I am thinking it must be the droid that determines the "listening code" of the device and memorizes it? If this is correct, could you actually pair two evices (a phone and a computer) to both use the same set of speakers or headset?
Depends upon the headset, I think. The Plantronics Voyager advertises being able to do exactly that....
However, my previous Motorola H790 (?) was paired with both my phone and my computer with no issues....I just had to remember to disconnect it from the phone to use it with the computer.
I was able to pair right away with a Plantronics Voyager 510. Must be an issue between the M Droid and the Sennheiser VMX
I'm unable to pair my Verizon Motorola Droid with my Voyager Pro bluetooth.
When I scan for devices, 9 other, nearby, but much farther away, devices are listed.
I've tried power-cycling my Droid and my Pro.
