Root sense ui theme. mm. port.
treyjones424
I have succesfully ported the xhero 2.1 theme from the droid. all credit given to xeudoxus for creating the theme and savoxis for creating the theme file i used.
here ya go.
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Velocity2.zip - 4shared.com - online file sharing and storage - download
Edit: use this mod, found by some members over at xda to get the like dock. [ADW Mod] Sense-Like Launcher *UPDATED* ADW 1.2.0, Standalone - xda-developers
fancy widget is the weather widget. google search to get it.
Screenshots:
Did you update this theme? I see the dock has changed.
You also need to rename it. Im sure thats going to be disconcerning to many people.
treyjones424:
Please note the following:
Inside my Velocity2.zip which contains the "template" for making a metamorph theme you will find a xml file named Velocity2.xml you can open this file with notepad, or any other text editor and modify the beginning of the file to change the name/creators/etc also you can rename the xml file to something like sense.xml. The xml will need to be the same name as the zip file however, so if you rename the xml, also rename the zip.
Sorry if this doesn't make any sense I am a bit busy
