williamj1
I wish to change back to a sense rom I think as I haven't been on one in ages, and I rather like them. However, I am thinking I would quite like to try a sense v2 rom, ported from the Desire Z / HD. Having a look on xda, there are about 10 serving this purpose. (Desire Android Development - xda-developers).
So what do you guys suggest I use? I would like it to have 720p recording, but that's my only criteria as well as sense 2. There are choices like...
- InsertCoin HD
- ReflexTsenseHD
- RCMixHD
- Avaritia HD
- Amongst many many others!
Problem is they all seem to differ slightly and I can't choose between them... so anyone has experience with any / recommend any?
Also, I currently use eMiui or Oxygen, so I have been using A2SD+ I think with an ext 2/3 partition. A lot of these mention ext 4, which I'm not sure if I have? Some mention Data2SD, and I haven't a clue what these are either. If anyone could help with this part of my question too, I would be very grateful
(I only have a class 2 card by the way, but performs fine with A2SD). I don't want to lose data in upgrading, and I switch roms lots so I need to be able to move data between roms. A2SD works fine for me, I would just like a little bit more storage than what I get. Even with my 512mb partition it is limited, so is this the solution?
Thanks.
- InsertCoin HD
- ReflexTsenseHD
- RCMixHD
- Avaritia HD
(I only have a class 2 card by the way, but performs fine with A2SD). I don't want to lose data in upgrading, and I switch roms lots so I need to be able to move data between roms. A2SD works fine for me, I would just like a little bit more storage than what I get. Even with my 512mb partition it is limited, so is this the solution?Thanks.
