Help Serious Calendar Issues
So, I got my Desire and thought everything would be fine. I'm not exactly new to smartphones but this problem seems to be beyond me.
Problem: can't store calendar event
Not even one.
It seems that it tries to load a calendar, it can't find anything. I also can't even create a calendar. Syncing? Yeah right!! I'm managed to sync my contacts and that was all.
Just to simplify things a bit, in my search for a solution, I noticed that I don't have an app called Calendar Storage. Does it seem right that this app is missing? Every one else seems to talk about it, but I don't even have it for some reason.
Any ideas about what I can do?
Welcome to Android Forums!
Open the Calendar app, go to Menu/Settings/Calendars and check that you have a Google Calendar selected. If you haven't previously created one you'll have to do so via the Google web site.
About Calendar Storage... it's not a user app so ordinarily you can't see it. It'll be there though, but running as a background service.
Hmmm,
calendar app, menu, more, calendars
Oh, there isn't anything to select.. I don't even have a pc sync standard calendar
I got nothin' but problems.
I've tried almost every idea I could fine in forums about adding an account but I still can't get it to add my google account.
HTC sense doesn't seem to be syncing.
I have nowhere to back up my files so I'm afraid to do a factory reset.
I got the HTC sync software to sync my contacts once and that was it. Since then, about a week ago, I've made numerous contacts changes and would really loe to back it up again.
Anyway, I think I could deal with all of these issues if I could just add a goole account or just get my built in calendar to work.
I'm on my knees everyone. Please help a guy out.
I synced my contacts using a method other than Google.
I can't recall how I did it, need to do it again, and would much rather just fix my calendar feature first, sync up with google, then sync the contacts.
