Root Seriously Help
I cannot get my note to go back to factory to save my life. I have done several reformat/ hard reset both through settings and recovery mode. I have flashed the stock rom a few times and everytime all of my info is always on the phone what do I do. I am ready to send it in for a replacement at this point but I also can't get my odin counter back down to zero.
Also just checked before my last restore my odin was at 6 now at 8 it is doubling with each restore.
Did you figure it out?
there are a few steps... mostly you will first need to use the reset tool, which does require you be rooted...then you will have to use a specific method of odin to get back to stock without resetting the flash counter.
let me know where you are in the process and I will be glad to help
