PLEASE HELP!!! My tablet has been bricked and i will explain.First of all i rooted my device with CWM and then i read on a blog about being able to change the pixel density and so i download it and i remember when i first launch the app it says warning "Do at your own risk" and so i change the ppi from "216" to about 320 ppi, yeah thats!!!And since i have titanium backup installed it says "the device needs to reboot in order for changes to take effect"and i press allow. So i reboot the device and then wait for it to turn on, and no chance to turning on. So i try pressing the
POWER BUTTON + Both (+) (-) and says "Updating... Please do not press any keys!" and then back on the black screen, i assume its still on because its lit on the black screen, but does not want to function, but don't no why.Its obviously bricked and when i go to recovery mode by
pressing POWER BUTTON + VOLUME (-) and when i was on that screen i wiped the User data and the Cache Partition and wiped the
Dalvik cache, and then Press "Reboot System" and goes to the black screen.
Fastboot does not work, but instead gets stuck on the green words "FASTBOOT",only Recovery mode works.I know for fastboot it is
POWER BUTTON + VOLUME (+) . I'm stuck, i've used nexus 7 ToolKit, even if its for nexus 7 i tried because i'm eager to get the tablet unbrick.It almost worked for me but not well good with that program, Im not even sure if Nexus 7 ToolKit functions with Sero 7 Pro. But maybe you can answer that. I don't know how to download adb, i think it has to do something with the Path system variable, now i've caused another problem. WTF!!! I backspaced the path variable and now its empty, is there any way to bring it back to the original "Path" or replace it for another Path variable.
Anyways,i tried DPI changer and it changes the density back to the current ppi "216". Does not recognize the device.So that does'ent work.And now the only thing i havent tried is inserting the following " >su #mount -o rw,remount /system #chmod 644 /system/build " in ABD,but dont have abd.PLEASE GIVE ME ANY SUGGESTIONS TO WHAT I CAN DO!!! BUT NOT "WHAT I CANT DO".
Also is there any place i can take the tablet to repair in.
