Root Setcpu question
Halcyon
Can anyone tell me whats the best settings for a newly rooted fascinate using setcpu? When I install it its set to min on both sliders. Not sure where I should start with it. Also I dont have any voodoo kernals loaded (yet) So I just want to get it set up to start playing around. Thanks!
Conservatively scaling with give you the best battery life. Also make sure you are auto-detecting your kernel. This will give you control of the sliders
