Help Settings from home page
Stick405
How do I get to "Settings" while on the home page without going thru the Settings Widget.. Most of my other phones, could bring up the "Menu" while on the home page with the settings option... Cheers :)
Pull down the right hand side of the screen from the notification bar.
Option should be there or accessible from there.
Sent from my Nexus 7 using Tapatalk HD
if your like me and would rather have the dedicated "menu" it can be added back.
However I am on cm10.1 I do not remember if this option was available on stock rom.
go to system settings then system/ navigation bar touch the unlock icon and touch menu icon then menu always show.
Daffy Duck.... You did it... man, you're good.... However, New Optimus, I'm not seeing the system/ navigation bar on my settings.... Cheers....:)
Are you on stock rom? 4.2.2? if you are you may consider using cm10.1 or one of the other many custom roms.
