ruthlessnature
Member
My fav. Boot anim. Is the one you had in 1.0.2 thats the one im using
Sent from my SCH-R530M
Are we using twrp or cwm to flash?
Thanks dual actually this is what I just did went into the message setting under sms input and changed it to gsm and now it works interesting Joshua told me about it and now long text are being sent
odd i didnt change anything in the build.prop except ro.Shabby.Version=104 which obviously wouldnt affect anything. here is the diff between 1.0.3 and 1.0.4
changed the boot animations and sound... the kernel has minor edits to init.rc have you tried reflashing it?
Hey shabby I know the 1.0.4 is a small update... any reason it would break the note 2 camera... worked fine on 1.0.3... maybe a build prop edit or idk.. any help would be appreciated thanks
Is 1.0.4 out yet or just for testers?![]()
First page third post.
my games runs smooth but I'm getting these vibrations sometimes on and off not sure why...
I went to my back up and did some checking... as long as i do not wipe cache and davlik it works perfectly fine when i update...so i started with my back up then 1.0.3 then 1.0.4 and lastly the note 2 cam zip and works perfectly fine...... works great so im
:beer:
Do I have to delete anything from system apps, gallery, cam, etc. before flashing note 2 cam zip?
Nope it takes the spot of the cam in the rom...looks exactly the same just has the added functions slow mo, fast mo and best face group photo that Ive noteced at least
Ok. Been looking all through here for the note2 camera zip. A lil help here please lol
I've got two camera's the 4.2 and the other one both works fine like the photosphere option. and slowmo is koo too
