[SGS3-R530M] Metropolis Rom [4.3 Touchwiz]
I cant stay in this rom longer then a day because after a while msgs start to act up I dont know why but I wish I knew how to fix it :/
Same here. It's why I'm back on ics. Hopefully the official released will have it fixed. Or maybe somebody will come up with a solution.
Sorry to bring up an old question but now that many of you have been running this ROM, how is your battery life? Just flashed and already seeing quick drains.
The battery drains faster than say BlackBean, AOKP, and CM but i dont see a difference over plain stock. All those features come at a cost.
I cant comment on the sms issue.
Shabby, im having an issue with 1.0.3. When i try to pull gallery2.apk out of the zip i get a corrupt file error. Ive dl a few times but always same result. Could you check it out?
Thanks.
Dunno that ROM last me all day just fine keep in mind if ya on 1.3 ya need to upgrade to 1.4 there was a bug mentioned by shabby and it was he snagged it while messing with boot animation files and that triggered both cores to run at the same time so that might explain fast battery draining for some. Me in the other hand I've yet to see any of those symptoms.
The only issues I have are the same graphic glitches that I get with all the 4.1 roms. I thought the battery was draining fast but I still get 19 hours with moderate to heavy use such as several rd 3min or more phone calls few games and bunch of texting this truly is awesome work thanks
To stop the gallery glitches just disable hw overlay under developer options how you get that battery life that's crazy
Thanks.
odd i was having the gallery glitches so i threw in another variants gallery from jb in hopes to fix it (it did for me at least)
1.3 1.4 What are these versions of???
Question ...
Do we have to download 1.0.3 install, plus download and install 1.0.4 also? Is there like a 1.0.5 that has all the fixes and its the full rom/download?
Thank You for your work.
Downloads
Latest version:
Metropolis 1.0.4 (update)
Latest FULL rom (as in start here if you are joining us :)
Metropolis version 1.0.3 (full download)
Bugs:
Flashing 1.0.3 will keep your data but require you to login into google again :/
paper artist will crash is you try to use camera
gallery FC's when trying to pick wallpaper
Old:
Metropolis Rom 1.0.2 (Update only)
Metropolis Rom 1.0.0 (Full download)
Question ...
yes for now you need to download 1.03 then install 1.04
I had accidentally restored another ROM while trying to backup this ROM and now when I try flashing this ROM from 1.03 to 1.04 I get a fail every time can anybody help
I wipe Delvik cache , reg. cache format data and system still get fails
thanks in advance
