legmando33
Exactly...I connected phone to PC and searched folders but cannot locate pics. I just want to get these off my phone.![]()
What is the name of the folder they are stored in? In the gallery.
See if you get 4g on another rom.
If you guys have flashed any 4.2 roms (cm10.1, liquid smooth) then your photos probably got moved to your data/media folders.
Try and use a root browser app to find and delete them.
Any app you recommend?
Tried them all still no 4g just 3g and 1x
go into settings and status, is anything unknown? sounds kind of like an nv corruption
What about back to stock?
Did u backup nv?
Network says unknown
Here
http://androidforums.com/showthread.php?p=5247794
Guess u didnt backup. Gotta read the stickies.
Metropolis came with hidden menu that wasn't hidden. Did you by any chance changed the settings in it? If so you can just go back in and restore.
if you are on metropolis try something for me, go to the IOThidden menu. and do the RTN menu. youll need your MSL but that should reprogram ya. hopefully![]()
Ill try it but what is msl
