does the s3 have fast charge? and if so does this rom support it?
thats a kernel feature
does the stock kernel support that?
no youll have to use the lean kernel to gain faster usb charging
www.shabbypenguin.com/Android/Apps/Mine/SPWallpapers-alpha-1.apk if anyone would like to play with it allplease bear in mind this is teh first app ive ever dabbled with. no idea why the images arent scrollable :/
just uploaded a version that should work on mdpi/hdpi and our devices (xhdpi). if anyone makes any cool wallpapers and or finds ones that can be freely used in this kind of stuff lemme know![]()
The images are scrollable for me on bb
Sent from my SCH-R530M
kernel tuner
i am slowly editing cm's wallpaper app to suit my needs that image wont be in there as idk if it is available under the creative commons or not but i have found some others that areunfortunatly its wallpaper that it sets doesnt seem to scroll and idk why
Is anybody still having trouble sending large text
... I may have found a fix in my many travels...
Me me lol yes long text are not converting to mms so you have a fix for it?
Sweet will give it a try as soon as I get home thanks sir![]()
I'm having the same issue with cm 10.1 so I tried to use that file but when I went to look for the CSC file under System/ it wasn't there.
Yes
And make sure u reboot after changing it
