Hey im going to lunch so ill try to keep it brief,
this started off as a rom based off of US cellular's JB update, now we have a very nice metro based rom, mucho gracias to every one involved
Screenshots will be posted here
downloads are in #3 Addons/themes will be in post 2
Instructions:
Download rom (derp)
copy to your phone (internal or external sdcard)
Boot into recovery (power + vol up + home til you see blue text in teh top left corner)
TWRP go into the wipe menu and choose factory reset (no matter what rom you are coming from)
CWM choose wipe data/factory reset on teh main menu
Flash the rom normally
since this is a new build (4.1.2) none of teh data is godo to crry over hence 1.X.0 bump so its best to start clean. i know what you are thinking "why do i need to wipe? i thought you had a super install script?" well i did, but the only bug i couldnt work out was how to deal with if people wiped system. since everyone seemed so damn happy hitting that format button i scrapped the entire script and now all of you can do it all yourselves.
Versions:
1.1.0
Rebased on MB2 (4.1.2 official)
Deodex'd/zipaligned
Pop up browser added
Bootanimation support
Init.d Support
Custom bootsound
1.0.5
fresh start based off leaked LL1 rom (4.1.2)
1.0.4
Custom power on song
Custom bootanimation
Bootanimations are done properly so should fix dual core bug, hopefully...
1.0.3
Actual bootsplash screen custom made by myself
Fixed updater script so its a bit smarter
Note II popup browser
Fixed gallery flickers
1.0.2
added init.d support
insecured kernel (adb runs as root)
boot animation support
1.0.1
broken
1.0.0
Based off leaked MetroPCS jellybean build
0.0.5 Public release
0.0.1 Initial version
baseline rom
