lonestariot83
I just wiped caches. Installed 3 then 5. Factory reset. Reboot. Worked good.
im on blackbean and im gonna make the switch to this.
so i should just flash .3 without wiping anything, reboot, flash .5 without wiping anything, reboot, wipe everything, reboot?
i got a software update notification from samsung when i first booted into the homescreen.
i declined it and it said something like if i say no i wont be able to update wirelessly.
anyone else get this?
nice shit bro niceok so ive been digging up touchwiz roms and taking their system apps and testing them on metropolis heres a cool themed secmms.apk from jellybean goodness that can be used on metropolis without any issues. and no this wont fix long sms prob just replaces stock look mms.apk
just go to system/app and rename original secmms.apk to secmms.bak if you want to keep a back up for any reason at all if not just delete it lol.
then place the one i provided in there then place finger on it till u get a option box and select permissions. then make sure permissions looks like this...
then last just reboot and if the messaging application is missing from the dock just go intto app drawer and drag it out and place it on the dock. enjoy
Download: http://db.tt/4kmOnFO8
I'm thinking about trying this out. Will I have to do anything special coming from the jellybean goodness ROM?
Look a few posts back from yours martymar. You should find the recommended process to flashing this.![]()
Is anyone else having problems with the exsd card? It randomly says that the sd card was removed it started yesterday and I got annoyed by it so I wanted to go back to stock rom but when I tried to restore it failed how do I go back to stuck rom? Help pls
Thanks, are there any know issues with this rom?
Samsung keyboard swipe feature isn't working properly but it comes with another swipe keyboard. Think that's it.
Thanks, I might try out the CarbonRom 4.2.2 rom instead.
So the keyboard is a deal breaker hu?![]()
It cant be the sd because i had it sense i first got my s3,and it was working fine i had this rom for about 2 weeks and yesterday it started to do this so thats why i want to go back too stock rom but it wont let me!?! do i have to do a factory rest and wipe everything?
I am good at reading white text. Thank you shabby.![]()
he was telling me earlier to check out for any responses towards that loooool i didnt think any1 was gonna noticed looool
