n4zty
Android Expert
Idk if anyone else has had this problem but my data works perfectly fine for a bit but then completely cuts of is there a fix for this ?
What modem are you using? And if the latest md3 I would try other modems.
I'm using the modem that came with the rom 1.3.0 build
i hit a lot of snags with it all and figured the 3-4 people who actually use this rom would like an update.
I had to get a new pc and it came with windows 8 instead of windows 7.
Sorry :banghead:
I picked up a laptop with windows 8. I formatted and installed window 7 within the hour. (that's how long it took to download a copy, hint, hint)
) of Windows 7 I can use but I'd much rather use the OS that came with the pc if possible and so im trying to make it work. As of now, I can decompile but not recompile. I suppose thats something...Heres a copy of a Note 2 keyboard that works with Metropolis for those interested in such things.
http://db.tt/PBKH32ku
Guys I completely lost data I'm using wifi right now but even if I switch to a new modem it still doesn't help what can I do?
I tried reflashing as well but it didn't help
What can I use to do a nv backup
Never mind I used the terminal to do a back up
Note: metro are doing alot of updates so you might be like me and a few others around the Metroplex and a few of my friends in different states that lost 4G/3G/no internet at all. Just post on metro's FB page or send them a private message and thy will respond letting you know if there is a problem in your neck of the woods.![]()
I manage to hit 12mbps again when towers came back up, I also change to automatic instead of metro pcs in settings.
How did you change it from metro to auto?
In wireless and network settings
Thanks n4zty is it good to set it to auto or just leave it?
no all teh mods need to be recoded
