This should answer some of your questions:Does the Note 3 have all the same bells and whistles and functionality as the SGS4?
It's the camera faster? I have a lot of lag from the time I touch the shutter button till it takes a pic
No I don't have it on. I had the SGS3 before this and it was fast.
I came from the S4 and the Note 3 does almost everything the S4 does. Some differences in the camera and some other little things.
Do all the s pen functions work if you use a home replacement app instead of touch wiz?
Yes, I have used a couple different Launchers and all the s pen features have worked fine. In fact the only thing I have found that doesn't work is swiping up for my magazine ..
Yeah thats only in the prime version I have it set to access Google now ... I was just stating in general some launchers will not support that feature
Yeah no problem ... And yeah all the functions will work fine with that the next launcher ..Sorry, was just piggy backing on your post so people are aware that it is a customization option.
Thanks everyone! Now I need help, all my pix that was on my SD card are showing in the gallery as little squares with a cracked in them. How do I get my pix?
Look in Settings for NFC, it's only used if you plan on bumping phones with someone. No, seriously. It's near field communications.Ok. They are back. What is that wierd looking N in the status bar? How do i make it go away along with the icon showing me what apps are running?
