Sharing options
Bradden
Ihave two options to share web pages... facebook and friend stream.
Can someone tell me what the difference is please?
Thanks
One uses the facebook app and one uses friendstream widget. I think if you share through friendstream, it just posts a link and through facebook app it is a little better.
Give it a go for comparisson, I may be wrong. Been a while since I used Friednstream.
I don't use Friendstream, but I believe you can post updates to multiple accounts at the same time with it (eg Facebook and Twitter), where as the Facebook option only updates your FB status.
