rahulwadhwani
Member
The Battery life of my Motorola doesnt even last a day. I am a moderate user.
Please tell me what should I do to extend the battery life.
Mine doesn't last a day too!
but im a super user!!
I use a lot of data flow!!
anyway, because it is a built in battery and due to the achievement of "thin"
the battery pack is set and cannot be changed.
Therefore here are a few tips that can help you improve your battery life.
1) if you are not downloading or tethering, use 3G. 4G connection uses a big chunk of battery life.
2) lower your brightness of the phone. (this is the main power usage!!)
3)set your account update to minimal!!!(It is important to reduce the data flow)
**The easiest way to save battery is to use the "smart action" control!!! You can set as much as you like in order to preserve your battery life. For example: When battery life is 40%, set data to 3G, lower screen brightness, etc..... You can save a lot of battery without knowing it if you use smart action.**
dude you have a Motorola Razr XT910 or Razr Maxx?I have excellent battery life. I can get 3+ days out of it if I want. With moderate usage about a day and a half. I would suggest you setup smart actions and use it. It works amazingly well.
I have ok battery life, but I keep chargers everywhere..work USB, car, home. I rarely am not near a charger so I always keep it as full as I can. I paid for the phone and screen and I kept the brightness at 100%! The Anker battery is also great to have in a pinch..goid luck!
Monoprice.com has several external backup batteries for cheap (I bought one for $13).
More specifics? Link? Sounds interesting. Thanks
then how come your battery last more than 3 days?It's actually the XT912, but yes the regular Razr.
dude there is an application named Droid Wall. I use that to stop the sync.Check apps that are automatically syncing data, change how often they sync to something less often (or, make it manual - that way YOU control when it syncs).
Big offenders are usually Facebook, weather widgets and mail.
okay. I am gonna try that.I set smart actions to do the following when the screen is off:
Turn off GPS, background data, Data, Bluetooth, Wifi.
So basically unless I'm using the phone everything is off. The 3 days + is with minimal usage. With some browsing, phone calls, downloading a few apps, etc I get 1.5 days.
You should really try playing around with it, it can do many different things and is definitely worth the time checking out.
Yes, he means that he switches off the background sync and cellular data when the phone is not in use.Do you mean background sync and cellular data??
