should i switch browsers?
that is completely up to you. i personally use the stock browser.
it isn't like we have a ton of choices.
give a few of the few that are out a shot.
to change, dload them from the market or app brain and install them...simple as that. when you go to open the browser it will ask you which one you want to use.
if you like it ...keep it ...if not...uninstall
dolphin hd is mentioned alot...and mozilla has a new beta out
give them all a try!
I grabbed the Dolphin browser because some folks said it was faster. I've noticed it is a bit faster.
However...and this is a big however, Dolphin has a flash block add-on and an Adblock add-on too. I like the tabbed browsing as well. Now it auto blocks all flash content and I select what I want to see.
Both are good browsers though i'm just warming to Dolphin.
While looking you might want to give Xscope a try. Much more functional than stock with many options. Lightning fast as well. Been using it for months and haven't used the stock browser since.
