TriumphLance
I'm on boost Mobile and my cellular strength bars meter seems to be lower than my old Virgin Mobile phones. But whenever I attempt to make a call the bars jump up to full bars rather than 2 or 3 is this normal?
4G signal is for date and 3G is for calling
My cellular signal definitely is stronger with 4g off. Oddly enough my battery doesn't seem affected either way its such a good battery.4g is mainly internet and it knocks you down to 3G/regular cell tower usage when you are making calls.
but if the bars are low i suggest you go down to 3G to save battery life.
No, it's not spark, it's just regular LTE, the "spark" is there to let you know data is moving. If you actually had spark, which is pretty limited to certain areas right now, you'd be able to tell the difference. You'd probably be getting 50 mbps+. Trust me, I have the same thing and I live in a regular LTE area but not far from a spark enabled area.
