Help Skype keeps quitting
Basically when I have skype running in the background it randomly quits meaning people can't call me on skype. It's pretty random and I can't work out a pattern for it. The only thing that I can think of that would cause this is that I forced it to SD using A2SD on my Desire which is running Leedroid. Do you think this is the problem and if I was to reflash Leedroid with A2SD+ with a partitioned SD card would this solve it?
Hope the post made sense and doesn't sound like idiotic rambling and thanks for the help!
Try moving it back to phone memory and see if the same thing happens.
I'm assuming its not being killed by as task killer or anything?
The other thing is that is may be killed automatically by android if it needs ram for something else. If that is the case you should contact skype and they may be able to fix this within the app
