Seems as though an issue with the Motorola charger. Swapped out to the old HTC charger and its charging faster now.
shortest charger wire I've ever had.. was going to replace it anyway
ya it was exceptionally short! Mine charged right up just fine tho.
What charger did you guys get? I'm using the regular desk dock right now (not HD dock), plugged into wall.
Got 1 Battery in the Phone and the other one in the External Battery Charger ... which I might add the external charger charges quiet fast.Not sure, I won't have that problemGot 1 Battery in the Phone and the other one in the External Battery Charger ... which I might add the external charger charges quiet fast.
The Droid Charge needs a 1000mA charger (rather than the 700mA and 800mA ones floating around) to charge in a reasonable amount of time. May be the same w/Bionic.
We got it as a part of the BIONIC bundle via CostCo - but you can get the same thing from Motorola for sure: DROID BIONIC by Motorola - Android Social Smartphone - Overview - Motorola Mobility, Inc. USA
In the section under the phone are the related accessories - the one called Battery Dock
I no longer have the Charge, but pretty sure the stock wall charger that came with it was 1000mA.what 1000MA charger are you using?
interesting. wonder when motorola will figure out that we need a higher output than 850MA.
